Equinox won't start, Stabilitrak service light
So, I have a 2011 LTZ, and this was my first time driving it in snow. I was trying to get up a hill, and it wasn't going well. Saw the traction control light flash as I began to spin. I stopped, and tried to move again, but just spun my wheels. So I backed up, got onto a dry patch, and moved forward again. I used my momentum to pull ahead into my neighbor's drive and then walked up to my place.
When I went back out to start it, I got a "Service Stabilitrak" message in the dash...and the Equinox won't start. It clicks, it has power, but won't turn over. I assume something went down when I was spinning my wheels before, but not sure what's up.
Any ideas how I can get her running again to get to a dealer? I have OnStar, if that helps. I tried looking at the diagnostics online, but it says all is well. My assumption there is it only runs diagnostics once a month, and is looking at old data. Not sure if there is a way to force it to run diagnostics, or how helpful that would even be.
Any help would be appreciated.
- j.
- j.
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> thrawn78731,
I’m sorry you are experiencing this issue with your vehicle. This may be due to low transmission line pressure. This is just a suggestion and is not meant as a diagnosis. I recommend consulting with a certified technician for an official diagnosis.
Have you had OnStar run On-Demand Diagnostics?
Louis
GM Customer Service
Louis
GM Customer Service
gilstone
August 6th, 2024 12:19 AM
islandarmor
Avalanche
315
September 24th, 2023 12:19 AM
heygb736
July 21st, 2016 10:58 AM
loismyles
Captiva
March 9th, 2016 7:09 PM
gilstone
August 31st, 2011 4:31 PM
blink, car, chevy, cost, equinkx, equinox, ir, light, lights, service, stabilitrac, stabilitrack, stabilitrak, start, wont
