Fog Lights
Fog Lights
My equinox did not come equipped with fog lights, I would like to add them. How difficult would this be?
not hard at all.
You could look at getting the originals or getting aftermarket. I would suggest some aftermarket ones, as the one in the nox are not the greatest. i replaced mine with some yellow HID. What i would suggest is, get the fog light button for the dash kit, and run a wire from fogs through the firewall and into the switch. If choose to go with a kit that uses HID, your looking a minimum 35 watts at 26000 watts. I would suggest having a relay that turns on those from the switch. Have the switch activate the relay, cause last i checked the switch on the interior piece is rated at 10amp 12volt.
Bringing a post back from the Dead. MrWiggy, do you have any close pics of your fog lights and blacked out headlights installed. I have ordered my wife's HID kit for Christmas and it will be here in a few days. I am debating on doing the blacked out headlights, but I would like to see how it looks first. Also your fog lights did you use the stock fogs and put HID's in those, or did you use aftermarket fogs? Thanks in advance.
samsonitus
September 15th, 2006 6:37 PM
mexican34
April 20th, 2006 2:26 AM
