Chevrolet Equinox
Platform: Theta
Front right brake pads keep; over heating and cracking
Old Jun 1, 2019 | 6:04 AM
atonjr's Avatar
Default brake makes a clicking sound
why does my 2006 chevy equinox braking system makes a clicking sound when brakes are applied hard?
Old Jun 1, 2019 | 7:20 AM
oilcanhenry's Avatar
Originally Posted by atonjr
I have a 2006 Chevy Equinox the front right brake pads keep; over heating and cracking. I put on new calibers and it still does it.
Caliper piston(s) might be stuck/corroded, but you changed it so that's pretty much out of the way. Might be a warped brake rotor, or something in the braking system is not allowing the caliper pistons to release properly.
Old Jun 1, 2019 | 7:28 AM
kevinkpk's Avatar
I agree, replace the caliper
Old Jun 1, 2019 | 7:32 AM
it is slightly possible that the rubber brake line to that caliper is bad and not letting the caliper fully release.
Old Jun 1, 2019 | 9:41 AM
ruley73's Avatar
Replace BOTH front brake hoses. They commonly rust around the mounting bracket. The rust builds up, crimps the hoses, and makes them work like a check valve. This causes the calipers to not release when they should. This problem is so common that I'd bet the hose was the problem all along on the right side, and I would not hesitate to replace the left one as a preventative measure.
Old Jun 1, 2019 | 11:55 AM
KChevy75's Avatar
The inside of the hoses can also delaminate causing the check valve type of effect and the wear you are seeing.
Another thing to consider is the brake pad material. I switched to semi-metallic on my suburban and it started eating pads every 2 months on the driver side front. Stranger yet, it would eat the inside pad way faster than the outer. The passenger pads had normal wear. I switched back to ceramic which is the OEM material and have not had a single problem since.
Old Jun 1, 2019 | 8:14 PM
Irish_alley's Avatar
I'm here for the party
x2 ive seen this a few times
Old Jun 3, 2019 | 1:35 PM
mrlee75's Avatar
I agree as this has happened to me
