Head Gasket Replacement On 3.4
Good morning, my daughter in law has a blown head gasket on her 2005 Equinox. For all intents and purposes this looks like a pretty straight forward job.
Has anyone done this job before? If we take it on vs. spending the money to have a shop do it we have a very short window. Any help on what tools, what parts (if anything beyond the gasket set) and so for that we would need would be great. I want to have everything lined up so I am not spending half of my time running to town and back.
Anyone have a procedure doc on this?
I think the good news is, this seems like a pretty traditional V6 configuration. Cam shaft is in the "right" spot, no timing belts to mess with, etc.
Anything anyone can provide for information would be greatly appreciated.
It's not a difficult job, but care needs to be taken in making sure the heads are true (not warped) and that the failure point was in fact a gasket, and not a defect in a head or the block. The 3.4 is an easy engine to work on, but getting to exhaust manifold bolts on the rear head can be trying. Use good gaskets and a manual with proper torque values as well as a good torque wrench are a must. I'd also recommend having the radiator cleaned/flushed and replacing a thermostat/gasket at the same time.
DOBERDEWD
December 11th, 2011 11:35 PM
gulfcoastjoe
May 4th, 2008 12:38 PM
Stirgen
February 5th, 2008 3:44 PM
