Chevrolet Equinox
Platform: Theta
How do install an auxiliary temperature gauge
Old Nov 19, 2023 | 9:40 AM
BSUD's Avatar
Default How do install an auxiliary temperature gauge
2007 Equinox
My temp gauge is not working and I was going to just put in my own mechanical Temp gauge. Where do I put the Probe from the gauge, does it go in a port in the head, between a hose or where??
Old Nov 19, 2023 | 5:33 PM
You don't want to remove the factory sensor because the engine won't work properly. So you would have to fashion some sort of hose adapter I guess. A piece of pipe to act as a coupler, with a hole drilled in it for your probe maybe. Sounds like a leak waiting to happen though. Maybe just cable tie it to a part of the water pump or thermostat. It won't be super accurate, but better than nothing.
are you sure it's the gauge that's not working?
Old Nov 19, 2023 | 6:02 PM
BSUD's Avatar
They actually make Temp gauges that go between the radiator hose. I just didn't know if it would be more accurate in a port somewhere.
Yes the gauge is not working it goes all the way around and sits on pegged. You can cycle key and get it back around but it does same thing. I've already changed out the coolant temp sensor and that didn't fix it.
Old Nov 19, 2023 | 6:20 PM
Maybe a product exists that fits where the block heater would go, but that's probably a huge job as they're not easy to get to.
No other ports I'm aware of.
I've already changed out the coolant temp sensor and that didn't fix it.​​​​​
I would check with a scan tool to make that at least the ECM is getting a good temperature reading.
Old Nov 20, 2023 | 7:46 AM
It is possible that the stepper motor for the temp gauge is bad. There was a problem with them around that time period.
Old Nov 20, 2023 | 12:06 PM
BSUD's Avatar
Yeah and that's reason I'm thinking of a Mechanical temp gauge. It would be cheaper than having the cluster gauge rebuilt.
ShellJ
Nov 7, 2025 4:46 AM
Mark_Cool
1988 - 1998 (GMT400)
Jun 25, 2022 1:26 PM
john2000
Apr 26, 2020 12:41 PM
Sonicd
May 13, 2013 2:48 PM
2001astrovan
Astro
May 25, 2010 7:07 AM
