Low Beam Headlights Suddenly Not working 2005 Equinox LS
My lowbeams/DRL suddenly stopped working. Have been looking for solution to this problem. Common thread I found was to replace the DRL relay. I did. It didn't fix it. Don't drive much at night but, when I do I don't like blinding other drivers. Any ideas or better yet, solutions that a 'Harriet Car Owner' could easily fix would be greatly appreciated. I'm not real keen on the idea of paying someone for something I may be able to do myself.
Thank you in advance.
RE: Low Beam Headlights Suddenly Not working 2005 Equinox LS
Have you checked out all the fuses? [/align][/align]I think you may have a burned out bulb and its compensating for the lost light by usingthe high beam bulb.[/align]
Might be the multifunction switch in the column. Tilt your steering wheel up or down to see if you have a bad connection.
Klimbo
July 10th, 2012 9:44 PM
