2004 Suburban No Low Beam Headlights
Old Jan 7, 2015 | 4:55 PM
monteu's Avatar
Default 2004 Suburban No Low Beam Headlights
Suddenly the low beam headlights don't work on 2004 Chevorlet Suburban. I have checked and replaced the relay. That did not help. So is it the dimmer switch? I cannot figure out to check the dimmer switch. Anybody have any experience with this about the low beams not working. What else should I check or replace? Thanks!!
Old Jan 8, 2015 | 11:28 AM
I would check the bulbs. It may be unlikely for both to be bad, but it could happen. You can check to see if the voltage for the low beams are getting to the bulb by unplugging the socket and checking with a meter.
Old Jan 8, 2015 | 1:27 PM
monteu's Avatar
Ok, I did that..........both bulbs when I tapped on them started working! Thanks
Klimbo
Jul 10, 2012 9:44 PM
shant
Feb 23, 2011 9:08 PM
Eric L
Sep 27, 2009 2:34 PM
mentalmom
Nov 26, 2008 6:05 PM
gzobian
Dec 21, 2007 10:29 PM
