Chevrolet Equinox
Platform: Theta
Low Oil Pressure Warning
Old Feb 21, 2020 | 1:34 PM
RedStone's Avatar
Default Low Oil Pressure Warning
Hello,
This is my first post. I had a low oil pressure warning on my 07 equinox. it started after going over a large bump. The engine doesn't seem low on oil and seems to run fine (no chugging or hard starts). I'm wondering if it's a faulty oil pressure sensor - but I can't find any videos or instructions on where to find the sensor or how to get it out. Is the oil pressure sensor in the same location as the rest of the 05-09 GM trucks/SUVs?
Regardless of if this fixes the problem, I am curious to find out where this oil pressure sensor is located on my 07 Equinox.
Thanks for the help
Old Feb 21, 2020 | 8:15 PM
ruley73's Avatar
Originally Posted by RedStone
Hello,
Thanks for the help
It's located in the middle of the engine block, between the starter and the left (front) exhaust manifold. Space is a bit tight there, but you should be able to remove the oil pressure switch without removing anything else.
Here's a video to show you. This is a 2005 Equinox w/3.4L V6, but all 2005-2009 models with the 3.4L V6 would be the same.
Old Feb 21, 2020 | 9:31 PM
RedStone's Avatar
That YouTube video was the only thing I could find as well. Is this underneath the vehicle? I wish the vid was more stable and wide angle.
Old Feb 22, 2020 | 9:42 AM
It is from underneath the vehicle.
Old Feb 22, 2020 | 4:33 PM
RedStone's Avatar
great! ​​​​​I found it and got the module replaced. Pretty easy fix when all said and done, but required a few special tools and knowing where to look
Old Feb 9, 2021 | 7:13 AM
Jeff Bowles's Avatar
Default 2016 equinox oil pressure issues
2016 equinox awd issues 50,000 miles. The emission system has moisture in in and when it gets really cold outside, the moisture freezes and the engine cnt vent the crankcase pressure and it blows out the rear main seal. At the shop now hope it’s covered under warranty.
QUOTE=RedStone;443345]Hello,
Thanks for the help [/QUOTE]
J C Smith
Aug 29, 2019 8:32 PM
Firemen175
2007 - 2013 (GMT900)
Apr 15, 2019 12:32 AM
Ssomave1961
May 9, 2018 2:10 PM
ruthie73
Jan 24, 2012 5:31 PM
indyrob
Mar 2, 2010 10:01 PM
