Chevrolet Equinox
Platform: Theta
Master cylinder replacement.
Old Jan 17, 2018 | 7:34 PM
confused's Avatar
Default Master cylinder replacement.
2010 Equinox After bench and then on car bleeding does the ABS need to be reset with a scaner?
Old Jan 17, 2018 | 8:14 PM
only if you can't get air out of the system...ie no pedal, soft pedal. What is the problem?
Old Jan 18, 2018 | 7:17 AM
confused's Avatar
Soft pedal. Haven't replaced it yet. Have heard it needs to be auto bled? By an ABS scanner. Just checking before I start.
Old Jan 18, 2018 | 8:02 AM
if the soft pedal started after part replacement or the system was opened; and the pedal gets hard after pumping it up....bleed it before replacing a mc. if the pedal slowly sinks to the floor and there is no loss of fluid external anywhere...the mc is leaking internally, replace it.
Old Jan 23, 2018 | 6:23 PM
confused's Avatar
See joeandtrix post 2010 equinx
