Chevrolet Equinox
Platform: Theta
Mom needs help with 06 equinox that overheats
Old Nov 16, 2019 | 6:13 PM
Emkaja's Avatar
Default Mom needs help with 06 equinox that overheats
06 equinox, had very little heat. Added coolant and bled system, had heat for about 10 miles than overheated. Mechanic combustion tested, and some vacuum test to suck out air, so fairly confident head gasket is ok,replaced water pump,tstat, backflushed heater core. No leaks noted anywhere. Still overheats! At wits end here as a single mom, need advice not rude remarks, please help! Fan does run.
Old Nov 16, 2019 | 6:54 PM
pressure test the rad cap or just replace
Old Nov 16, 2019 | 7:24 PM
Emkaja's Avatar
only cap I see is overflow reservoir
Old Nov 16, 2019 | 8:31 PM
whichever one keeps the system pressurized. It should say something like 15 PSI on it.
Old Nov 17, 2019 | 5:00 AM
ruley73's Avatar
Do both fans run?
What temp does the gauge indicate?
Did you test and/or replace the coolant lid?
BadKarma6
Feb 5, 2023 11:11 PM
Rosemary Kosinski
Jan 19, 2022 9:27 PM
Kay525
Dec 17, 2018 11:57 AM
cfrontz
Jan 10, 2016 11:15 AM
tloliver
Mar 8, 2010 6:38 PM
