Need help with 2007 3.4L
My 07 equinox was leaking at the gas tank and it was the fuel pump inside of the gas tank. It was not a recall but covered under a warrenty at the chevy garage and paid in full. I am now having stability control and traction control problems along with idle problems. I am suspicious that they are related.
This is late but there was actually a recall on the fuel pump (of 2007 equinox at least). Chevy sent me a letter regarding it, however it only applies if the pump causes your gas to leak. I have had all the problems listed here since I purchased the car 3 years ago. I've had tune ups, replaced EGR valve, everything you can think of, but nothing worked. I had given hope before the recall came in when my mechanic told me it had to be the fuel pump within the tank and it was just to expensive to fix until the car quit completely and I had to. So excited when I got the recall though, and I took my car to the dealership only for them to do absolutely nothing because I couldn't confirm that my fuel was leaking. I tried to tell them i had been told my fuel pump was the problem, but they didn't care and said if they even looked at my car it would cost over onehundred dollars. Before getting the Chevy I had always considered myself a Ford man. Needless to say, I still am after this Equinox. I will not be buying another Chevy, that's for sure.
As I previously said, the fuel pump would have nothing to do with the Stabilitrak/Traction Control being disabled. I don't know who your mechanic is, but they were incorrect.
There was no recall for the fuel pump, just a special coverage campaign. If it were a recall, they would have been required to replace the fuel pump, no questions asked, regardless of it's condition. I received said letter as well. It instructs you to hold onto the letter as long as you own the vehicle and if the part ever fails in the manner described, they will replace it for nothing. The dealership that replaced our fuel pump told us beforehand that if the issue did not match what was described in the letter that they would charge us an hour's labor just for putting it on the lift to look at it.
We'd be happy to help you get your Equinox running good again. Post the mileage, a more specific description of your issue (when does it stall/misfire?), any troublecodes that have been retrieved (many auto parts stores do this for free), and a list of parts that have been replaced.
I have a 2007 Pontiac torrent with 135,000 miles that started showing service stabilitrak service traction control. Then it started slipping between 2nd and 3rd. Took it to a friend's shop for inspection and he recommended taking it to the dealer to have the transmission checked out before putting any money into anything else. Dealer said it needed an egr valve at the tune of $600. And transmission replaced at cost $4,500. After reading the these threads I have replaced the egr and pull fuse 33. Codes gone and I will drive it tomorrow to see if they reapear. I was wondering if anyone else had the transmission slipping and did this fix it?
I have the p0404 and p0449 happening. I have put 2 new different Delphi EGR Valves on and I am still getting the p0404 code. I have put a new AcDelco purge valve on and I still get the p0449 code. I even replaced the Solenoid on the canister underneath my vehicle. My vehicle has recently started slipping or flaring up going into 3rd gear. The information everyone has provided here (great by the way) is pointing to a simple EGR valve replacement. Now my dilemma is I have already put 2 new ones on. Do I need to put a certain brand on like an AcDelco EGR valve? I also don't get how this have anything to do with the transmission shifting to 3rd. If you guys are still around I will appreciate any help. I am to the point where I don't want to throw anymore money at parts unless I'm sure it's going to work. My dealership wanted me to pay them nearly 400 dollars to put and OEM AcDelco EGR valve on and they couldn't guarantee it would solve the issue. I asked them about the wiring harness and they said it wasn't that. Thanks in advanced. Looking forward to replies. - Josh
kennygeorge
Sep 28, 2011 9:47 PM
lewis_75
Dec 22, 2007 9:14 AM
littlec984
Jun 23, 2007 12:48 PM
