Chevrolet Equinox
Platform: Theta
oil pan gasket and electric parking brake
Old Oct 10, 2023 | 9:32 AM
NOXbill's Avatar
Default oil pan gasket and electric parking brake
A couple of questions about my new to me 2020 Equinox 1.5L turbo.
1 Is the oil pan drain plug gasket reusable? Never seen one like it.
2 Owners manual says that some type maintenance is required on the electric parking brake.What type maintenance is this?
Old Oct 10, 2023 | 12:53 PM
BlueOx's Avatar
You might get away with it but replacement is always best practice. These fit my '22 1.5L, yours is probably the same but verify.Drain Plug Gasket OE Part # 12616850
Drain Plug Gasket Fel-Pro 70820
Drain Plug Gasket NAPA / MAHLE Part #: MOG B32655
All the manual seems to state is a procedure to verify the brake holds. No further guidance is given beyond, bring it in for service.You can download info from Mitchell for about $20. Make an afternoon of it. It will answer so many of the questions you'll see on the forum.
Old Oct 10, 2023 | 2:08 PM
NOXbill's Avatar
I just figured out that the drain plug is recessed for the gasket. I thought it was more complicated than that is why I was asking.
Thanks for the reply.
bill
Old Oct 10, 2023 | 2:46 PM
Mine is. the rubber gasket is pressed onto the plug. Still no issues after 70k
If it doesn't seep then you're good to go. It might wear out eventually.
probably lubrication to keep it from rusting and seizing up.
Old Oct 11, 2023 | 8:36 PM
NOXbill's Avatar
Mine is also the rubber gasket but not pressed on. With the head of the plug machined it looks like an O ring would work just as well.
grandsub
Mar 21, 2021 12:59 PM
impalauser
Apr 3, 2012 8:02 PM
stldrgnrdr
Aug 30, 2010 9:06 AM
cleft_asunder
Oct 17, 2009 11:36 AM
AndyCYXU
Jun 25, 2008 8:15 PM
