Power steering pump removal.
I have a 2016 equinox ltz AWD with a 3.6.
Took pasenger side tire off and access panel.
Remove belt
Got the lower and higher 2 bolts off going through the pulley.
Removed the hose and the steel line.
Disconnect the fluid restore.
Removed a bolt lower on the right, appeard it might be connect t apeice that connects to pump.
Going to get tack under there tomorrow.
Any help will be appreciated.
Thanks Eddie
Remove belt
Thanks Eddie
Danmc00
Feb 18, 2013 9:02 AM
Texas Fingers
Mar 23, 2011 5:46 PM
