Chevrolet Equinox
Platform: Theta
Radiator Fans On After Engine Off
Old Sep 1, 2023 | 12:39 PM
rcchevrolet's Avatar
Default Radiator Fans On After Engine Off
Recently engine fans turned on after the engine is off, and after 2-4 minutes fans turned off.
The engine coolant temperature gauge shows normal temperature under all driving conditions.
The coolant reservoir shows an unusually high amount of coolant.
Any and all comments would be appreciated.
Old Sep 2, 2023 | 11:33 AM
fabber39's Avatar
Default Radiator fans on after engine off !
CHECK YOUR COOLANT LEVEL ! Wife's Equinox was doing this, and the coolant level was low ! A 50/50 mix Prestone GM Vehicles Dex Cool, or a General purpose Anti-freeze with the 50/50 mix will do.
Please check the level when the engine is cooled down.
This might help !
Old Sep 5, 2023 | 8:21 PM
oilcanhenry's Avatar
Sounds normal to me. Just be glad you have coolant which you can run past the "top" mark without harming anything.
Old Sep 7, 2023 | 9:19 AM
Problem solved. Replaced the thermostat and replaced the coolant. In a kitchen pot tested the old thermostat by placing it in 195-degree water and it marginally/slightly opened.
Thank you for your replies.
9/9/23 Correction from the manufacturer temperature is 185/190 degrees.
ILosMasTeR
Jan 24, 2017 8:43 PM
Davpmars
Apr 11, 2016 10:44 AM
kountrygal318
Jun 15, 2015 1:03 AM
petryaw
May 5, 2012 12:20 AM
tom5170
Jun 9, 2010 12:13 AM
