Chevrolet Equinox
Platform: Theta
Reduced Power
Old Dec 24, 2010 | 7:01 AM
gwicks100's Avatar
Question Reduced Power
Im in need of help ! I have 06 Equinox untill-it started raining. The sunroof leaked getting everything wet. Know along with the check engine light there is the reduced engine power & traction control lights on. Know im getting codes P1125,P2138,P0120,P0700 & P0455 . Where should I start ?
Old Dec 26, 2010 | 6:55 PM
Barricade643's Avatar
Do you know what those codes are for? That is likely the root of your problem. Find out what the codes mean, and fix them. I know the p0455 is for the EVAP control module, as for the other ones I have no clue.
Old Mar 6, 2011 | 7:55 AM
Timthegmtech's Avatar
check gm bulletin there is a bulletin for water intrusion getting into the bulkhead connector and causing a short make sure you sunroof drains are clean
Old Mar 6, 2011 | 8:12 AM
here is the bulletin number 07-06-04-019D
Old Mar 6, 2011 | 8:15 AM
the p0455 is a evap large leak there is also a bulletin for that the number is09-06-04-001
dgordon
May 23, 2024 7:08 AM
Jazzybelle4you
May 23, 2012 12:33 PM
vivero
Jun 24, 2007 12:23 PM
vivero
Jun 23, 2007 2:38 PM
