Chevrolet Equinox
Platform: Theta
Stabilitract, traction control, ABS
Old Mar 25, 2015 | 4:56 PM
sjmclendon's Avatar
Default Stabilitract, traction control, ABS
I have a 2009 Equinox and My service stabilitract, service traction control and ABS lights have been coming on together. I took it to the shop last week and they put new tires on. Said my wheel berrings looked fine. It fixed it for a week. Now the lights are back on and the car is still driving fine. I went by my mechanic and he scanned it and said it was the right rear speed sensor which usually means a wheel betting but they had jut checked them last week. What could it be?
Old Mar 26, 2015 | 1:26 PM
ruley73's Avatar
It could be a bad right rear wheel speed sensor or a problem with the wiring associated with it. There isn't much to "check" with regard to the bearing or the speed sensor. They are either working or not working. A bearing usually makes noise that varies with speed & load when they go bad. Checking for excessive play in the bearing is not a reliable indicator of whether or not they are good/bad. I've replaced at least a dozen hub assemblies on my own vehicles over the years. They all made noise when driving down the road. All but one didn't feel loose upon inspection. The sensor can be replaced without replacing the wheel bearing/hub assembly, but might as well be replaced if the bearing is bad. Many new bearings come with a new sensor.
jt123456
Jun 27, 2018 3:33 PM
mrbutler
HHR
Aug 7, 2014 7:54 PM
r3z
Mar 24, 2008 11:35 AM
AAHTahoe
Oct 3, 2007 4:22 PM
