T-IV ATF question
T-IV ATF question
My 09 Equinox requires T-IV ATF fluid. I can purchase the stuff for > $20 per quart at my unfriendly Chevrolet dealer or $6.34 per quart at the local Toyota dealer. From what I have read this fluid was developed by Toyota so I see no need to purchase official Chevy stuff.... Anyone got a different opinion?
Professional Mechanic
They are the same fluid. Valvoline also make a compatible fluid which is sold at major chain stores, not sure of the price though
I've been running the Toyota T-IV for over 30K miles with no problems. It is the same stuff GM sells, just in a different bottle. I would be reluctant to use any other fluid unless it says it meets specification JWS 3309 on the bottle.
There are plenty of aftermarket ATF that meet the spec. The Vavoline specifically states Toyota T-IV
The Chevrolet factory service manual specifically says "Dexron®III automatic transmission fluid is not compatible with this transaxle. If Dexron®III ATF is used, transaxle failure will result." An excerpt can be viewed here. Per a TSB, GM now specifies Dexron-VI for all automatic (but not manual) transmissions that previously used Dexron-III so that means the same advice applies to Dexron-VI.
The fluids that Valvoline make supposedly meet the specifications for both Dexron III and Toyota T-IV (among others) Now ask yourself, exactly how safe is it to use for any application that recommends one or the other? Sorry, but when the factory service manual says that using one of these specific fluids will cause transmission failure, it is not worth the risk.
The only aftermarket fluid I would use is Mobil ATF 3309 which is made specifically and exclusively for use in applications where Toyota T-IV or equivalent is specified. I highly doubt that you will find this on the shelf at any auto parts store. I'm confident that some places could order it, but it probably costs at least as much as T-IV does from a Toyota dealership.
In this day and age you really need to be careful when it comes to fluids. The fluid in the bottle may be harmful even though the label seems to imply that it will work fine. For example, earlier I said "GM now specifies Dexron-VI for all automatic (but not manual) transmissions that previously used Dexron-III", but yet the webpage for Valvoline Dexron-VI says it "is fully backward serviceable, and can be used wherever DEXRON®-II and/or DEXRON®-III are recommended." The average Joe is going to read that and think to himself "well, the owners manual for my Saturn says to use Dexron-III in my manual transmission, so this should work fine", but it will make his Saturn shift very rough because Dexron VI has a different viscosity than Dexron-III
Good4JG (July 10th, 2021)
All I am stating is there are other options that will likely not cause an issue.
At work we use BG products. They make a universal synthetic that works for ALMOST all trans fluids. We have never had a single issue. BG stands behind there product. It most cases it exceeds the manufactures specs. You will find BG products in many dealerships.
BG Products, Inc.
http://prayertr.ipower.com/swbgaz/media/Bg$20Universal$20Synthetic$20ATF$20Application$20C hart$5B1$5D.pdf
BG Products, Inc.
for a gallon
ncseahawk
February 15th, 2010 11:18 AM
