Transfer case issue 2011 awd Equinox 2.4
Guys, need help. New to the forum and wo seeing what would be better and how much should I spend in this.
I am at my local GMC dealer and checking my car, after they checked they noise coming from the front, they say it is the transfer case, car is 93K on it and after some recalls 1.- Cat converter replaces 2 months ago and Power steering as well both under warranty this has. Me.
8 K miles ago I did also replaced the timing belt due (no special coverage and GM did not help at all).
Should I get rid of the car? Is it about time?
He much should I expect to spend on this? Thanks
gio dan (January 7th, 2020)
my K-1500. It's never even seen a shop yet.
gio dan (January 10th, 2020)
$3690 usd @ My local GMC
Bottom line, when he checked he found metal on the transfer case, suggestions?
I guess it is time to trade it in right?
I went to GMC and they say $3690 to replace transfer case !!! Then I went to my trusty local shop and he told me I need t go to a Tranny shop and they will charge around $3000.
gio dan (January 22nd, 2020)
Actually your transfer case is not in the front of the vehicle. It's located behind the transmission, so I question the idea that it's your transfer case. And if the fluid has never been changed you are going to have some metal from the break-in period of the vehicle. Might more likely be your front differential that is the issue here, and not the T/C.
oilcanhenry (January 23rd, 2020)
overrunwithsons
July 18th, 2010 6:01 PM
