Chevrolet Equinox
Platform: Theta
transmission cooler lines
Old Nov 14, 2016 | 10:21 PM
7474's Avatar
Default transmission cooler lines
2007 Equinox LT AWD
After exchanging the transmission fluid I noticed the cooler lines had a significant amount of rust and looked quite brittle.
Going to replace the lines and exchange the transmission fluid again. Will exchange the fluid a 3rd time. This is a process I have read about on Honda forums regarding my Odyssey. Figured I would also apply to my Equinox.
Was able to find the T-IV ATF at Toyota for $5.34 a quart. Didn't even check a GM dealer and I have heard it runs at least $17 a quart.
Anyone complete the transmission cooler line replacement? Any feedback and tips would be greatly appreciated.
Thanks
Old Nov 15, 2016 | 6:41 PM
ruley73's Avatar
Originally Posted by 7474
2007 Equinox LT AWD
Thanks
I have changed the transmission cooler line assembly (p/n 15781494; thread link here). It's fairly easy to do. Drain the fluid by removing the drain plug, replace the lines, and replenish the fluid. Draining the fluid is actually not necessary, but I was due for a fluid change so I did it anyways. I measured about 4.25 qts when I drained the fluid. The lines are held to the radiator with a pair of quick disconnect fittings. You'll only need to remove the small clips instead of the whole fitting. I used a small flat head screwdriver and a needle nose pliers to remove them. There are three slots in each fitting that the rounded edges of the clips go into so be sure to reinstall them correctly. The assembly is fastened to the transmission with one 10mm nut. The torque spec for this nut is only 80 in-lbs so don't over tighten it. The GM service manual says that you should replace the cooler line seals in the transmission (visible when hose assembly is removed; p/n 24221233) and the two clips (p/n 24205103) that hold the assembly to the radiator. I don't feel that replacing these items is necessary unless they are damaged.
I recommend removing the transmission end of the hose assembly first to allow the fluid to drain out. It's less messy than removing the radiator ends first. When reinstalling the new hose assembly, install the clips into the radiator fittings first. Then push the lines into the fitting. You'll hear a click when each hose locks in place. I've attached instructions below in case you need them.
2005-2009_Equinox_Torrent_3.4L _Aisin_transmission oil-cooler-line-replacement.pdf
2005-2009_Equinox_Torrent_3.4L _Aisin_transmission_fluid-cooler-hose-pipe-radiator-quick-connect.pdf
Old Nov 15, 2016 | 7:38 PM
7474's Avatar
Thanks a lot Ruley, greatly appreciate all of the information.
Where do these PDFs come from? I see them on many posts.
Thanks again.
Old Nov 15, 2016 | 8:51 PM
ruley73's Avatar
Thanks again.
My local public library offers free access to an online auto repair database for it's members. The database has repair procedures, wiring diagrams, and TSBs/recalls which can be downloaded as PDFs. Your local library might offer something similar.
Old Nov 18, 2016 | 8:01 AM
7474's Avatar
Thanks. What is the name of the online data base?
Changed cooler lines out last night. Thanks for your assistance.
Old Nov 19, 2016 | 2:32 PM
ruley73's Avatar
EBSCOhost is the name of the database. It appears they source most of their material from the respective manufacturer.
Old Nov 22, 2016 | 10:27 AM
7474's Avatar
Thanks for the info, I will check to see if our library has access.
Old Sep 17, 2024 | 5:42 PM
Hampton0223's Avatar
Attachment 9548
Attachment 9549
quick question? i have my new trans cooler lines and i am going to install them, are the clips always needed?
Old Sep 17, 2024 | 5:43 PM
are the clips mandatory? i have my new lines and they did not come with clips??
