Window washer fluid pump
My 2005 Equinox LS AWD has a full washer fluid reservoir, but no fluid comes out when I activate the washer. I tried to find the fuse for the washer fluid pump, but don't know which fuse/relay it operates off of. The labelling on the fuse diagram does not indicate a specific fuse for the pump.
Is the pump working at all, if so you have to play with it, my wife ran hers dry, and it took about 2 to 3 days to reprime the pump, fill it all the way to the top with the appropriate washer fluid and once in a while just push the windshield washer button,
may take awhile but it should work
The front and rear wipers have separate fuses. The washer pump circuit for the rear window goes through the fuse for the rear wipers. Likewise, the washer pump circuit for the front wipers goes through the fuse for the front wipers. Both of these fuses are located in the underhood junction box.
I posted a picture that labels the fuses and relays below. This same picture can be found on page 5-82 of your owner's manual.
![Window washer fluid pump-2005_equinox_uhjb.jpg](https://chevroletforum.com/forum/attachments/equinox-terrain-23/6728d1459881379t-window-washer-fluid-pump-2005_equinox_uhjb.jpg)
croberts
May 7th, 2011 4:31 AM
