Chevrolet Equinox
Platform: Theta
Window washer fluid pump
Old Nov 27, 2008 | 6:41 PM
mthoodequinox's Avatar
Default Window washer fluid pump
My 2005 Equinox LS AWD has a full washer fluid reservoir, but no fluid comes out when I activate the washer. I tried to find the fuse for the washer fluid pump, but don't know which fuse/relay it operates off of. The labelling on the fuse diagram does not indicate a specific fuse for the pump.
Old Mar 8, 2010 | 10:23 AM
ffmed6134's Avatar
Is the pump working at all, if so you have to play with it, my wife ran hers dry, and it took about 2 to 3 days to reprime the pump, fill it all the way to the top with the appropriate washer fluid and once in a while just push the windshield washer button,
may take awhile but it should work
Old May 8, 2014 | 4:56 PM
adman60's Avatar
Where is the fuse for the window washing pump on a 2005 chevy equinox?
Old May 8, 2014 | 8:07 PM
ruley73's Avatar
The front and rear wipers have separate fuses. The washer pump circuit for the rear window goes through the fuse for the rear wipers. Likewise, the washer pump circuit for the front wipers goes through the fuse for the front wipers. Both of these fuses are located in the underhood junction box.
I posted a picture that labels the fuses and relays below. This same picture can be found on page 5-82 of your owner's manual.
JoeBlow
Nov 24, 2011 10:05 AM
Thadeus13
Mar 21, 2008 12:45 PM
johnboy
Dec 3, 2007 7:52 PM
bigtim
Feb 7, 2007 8:51 PM
