1990 G20 Door lock relay (LOCATION)?
Old January 22nd, 2011, 8:22 PM
kanyons's Avatar
Default 1990 G20 Door lock relay (LOCATION)?
I'm trying to find where the door lock relay in on my 1990 G20 Sport Van. I've heard it is right under the driver side dash, but it's not there on mine.
Old January 23rd, 2011, 12:23 AM
kanyons's Avatar
Default I'm new to this.
Am I doing something wrong, because I've had 39 views and ZERO replies.
Old January 23rd, 2011, 5:12 PM
RacerX's Avatar
look on the other side, the passenger side.
Old February 4th, 2011, 2:22 PM
anjy834u's Avatar
it has to be somewhere near driver or passenger seat.
Old January 22nd, 2022, 11:27 PM
jimmydriver's Avatar
Buy a new one. See what it looks like. Look for something that looks the same. Once you find it Show us a picture please.
Old February 1st, 2022, 3:11 AM
William Kisselstein's Avatar
It's bolted to the body side in behind/beside the parking brake pedal. Follow the wires. Because PW/PL were options, there is a whole add-on harness that runs across the body from door to door, into the relay, plugs into the fuse block, and has a ground on a tab way way up under the left hand cowl behind the dash.
If yours aren't working, perhaps someone has removed it. The windows will run without it but the locks require it.
hfallek
September 13th, 2011 11:21 AM
pax
August 13th, 2011 2:25 PM
Mastiff
July 12th, 2010 8:39 PM
railroader1969
Silverado & Fullsize Pick-ups
May 30th, 2010 12:00 PM
joelwolverine
August 18th, 2008 2:35 PM
Quick Reply: 1990 G20 Door lock relay (LOCATION)?
