1990 G20 Door lock relay (LOCATION)?
I'm trying to find where the door lock relay in on my 1990 G20 Sport Van. I've heard it is right under the driver side dash, but it's not there on mine.
It's bolted to the body side in behind/beside the parking brake pedal. Follow the wires. Because PW/PL were options, there is a whole add-on harness that runs across the body from door to door, into the relay, plugs into the fuse block, and has a ground on a tab way way up under the left hand cowl behind the dash.
If yours aren't working, perhaps someone has removed it. The windows will run without it but the locks require it.
railroader1969
Silverado & Fullsize Pick-ups
May 30th, 2010 12:00 PM
joelwolverine
August 18th, 2008 2:35 PM
