2001 Express Cargo 2500 Stereo Wiring
Old January 18th, 2020, 2:34 PM
William Stauffer's Avatar
Default 2001 Express Cargo 2500 Stereo Wiring
I have been attempting to replace the stereo on my 2001 Chevy Express Cargo 2500. I've installed stereos in every vehicle I've ever owned myself so I generally know what I'm doing. However, on this van whoever put the after market stereo in it that it had when I acquired the vehicle, they removed the factory wiring harness and put a wiring harness from a different type of vehicle in it instead of buying a wiring harness to fit the factory harness. So I've got no clue at the moment what each color wire for this Van's stereo wiring is for. I've tried to look up a wiring diagram for my van online but havent found anything to match the wiring in the van. I've tried wiring using the harness that was already there but it always blows the fuel and when plugged in the van wont start so there has to be some wires that are not properly placed.
I've provided a picture of what the wiring looks like and the harness whoever put in it used. Is there anyone that can tell me what each colored wire for this vans stereo represents so I can get this new stereo properly installed?
Old January 18th, 2020, 3:16 PM
you can get wiring diagrams here:
http://www.bbbind.com/tsb-wiring-diagrams-database/
all you have to do is register an account. It's really useful
Old March 24th, 2021, 10:01 PM
pierre-mike Le meliner's Avatar
Default Same here
Hey I just get a express 2001 as well and I'm trying to change the radio
Did you found a solution or a diagram it will help me as well thanks
Old March 25th, 2021, 9:39 PM
pomerlo's Avatar
You might be done with it. If not this will help.
Old March 27th, 2021, 9:54 PM
William Kisselstein's Avatar
FWIW, GM wiring have used those color codes on the speaker wire for ages, my G-vans are the same.
It is very easy to confuse the grey speaker wire with the grey dimmer wire.
klockw243
October 30th, 2015 5:07 PM
Irunthesystem
Equinox
January 28th, 2012 2:32 PM
Mnguyen
January 1st, 2012 9:50 PM
checkerdchkn
August 19th, 2011 10:57 PM
mgiasson01
September 15th, 2008 8:14 PM
Quick Reply: 2001 Express Cargo 2500 Stereo Wiring
