2004 High-Top Chevy Express 1500 Leans
New User
Awaiting E-mail Confirmation
This van has under 100k miles and everything is great except for this problem. It is most noticeable in curves, but is also noticable with the slightest road slope -- both of which are MUCH worse than I experienced a couple of years ago. I replaced the shocks with GM Orig Equipment for the first time about 18 months (about 10k miles) ago but the problem continues to get worse. My allignment shop tells me that all steering and suspension parts look fine. The Firestone Destination LE2's are about a year old and have around 8k miles on them. Prior to this it had the prior version of these (Firestone Destination LE's).
What could the problem be?
check stabilizer bar links. they can rust out. Or sagged out springs. Your high center of gravity makes things worse.
New User
Thanks. Will do. Also, will the addition of a rear stabalizer bar make it handle even better and also in high wind situations and with semi's blowing it around on interstates?
yes it would. but beware that it also limits the amount travel in your suspension, making it easier to get stuck in holes etc.
