91 Vandura G1500 fuel issue
So my van left me stranded outside the liquor store yesterday. Worse places to break down I suppose. Anyway it's not getting fuel. It will start if I pour gas into the throttle body. I had this issue a couple months ago and I replaced the fuel pump and sending unit. I doubt it's that again. Bad connection maybe. Yes there is fuel in it.
Does anyone have a fuel pump wiring diagram for these? Know where the relay is? Ideas of what to check?
Thank you
Thank you
Do you know if there is a resistance value to check for on the ICM's?
Thanks
Can you hear the fuel pump spinning? If stuck sometimes a hit to the center of the tank bottom will get it started...but don't shut it off until you are home. Getting power to the pump? Getting power to the injectors? What brand of pump? I had an 87 s10 that had a parts store fuel pump last 9 months. Carter I think. I bought GM from the dealership the next time. It could still be the pump but also could be a lot of other things.
https://charm.li/Chevy%20Truck/1991/G%2010%20Van%20V8-350%205.7L/Repair%20and%20Diagnosis/Transmission%20and%20Drivetrain/Automatic%20Transmission%2FTransaxle/Testing%20and%20Inspection/Symptom%20Related%20Diagnostic%20Procedures/Diagnosis%20By%20Symptom/Engine%20Doesn%27t%20Start/
https://charm.li/Chevy%20Truck/1991/...elay/Locations
https://charm.li/Chevy%20Truck/1991/...n%27t%20Start/
I need to look up a wiring schematic and understand this. I'm not great with electrical, but think it could be the relay
Ok so below the fuel pump relay is a red wire coming out of the harness. Disconnect the clip, run power to the red wire and the fuel pump should run. In my case it does. Ok good.
However I still can't start it. So it's gotta be either clogged injectors or this cracked fitting on the throttle body is leaking enough fuel so that I'm not getting adequate pressure to the injectors. POS old van. I'll JB weld that fitting on and see how long that holds. Then get back to the fuel problem.
You can see the stream of gas if you look closely.
This van needs a new engine and is not worth buying a new throttle body for.
Isn't too likely that both injections die at the same time. Did you check power to the injectors? I think the 12v is constant and the ground is switched. Injector noid lights aren't that expensive. You can also disconnect the fuel line and check flow into a bottle. I don't recall there being a pressure test port but the pressure is low compared to more modern EFI.
