Front Impact Sensor
Old May 30, 2024 | 6:25 PM
IZZI613's Avatar
Cool Front Impact Sensor
My 08 Silverado has a cracked sensor on the driver side...i have been looking all over for a replacement. The # on the sensor is AA10034, is there a replacement part for this that is compatible? Or do i have to replace it with the same part number, as mention i cant find it..., funds are limited as well,,,so i have been on EBAY...any help is greatly appreciated
Old May 31, 2024 | 9:04 AM
jfmorris's Avatar
Does it look like one of these sensors?
https://www.rockauto.com/en/catalog/...sh+sensor,1564
I am guessing it is the 3rd one in the list. I can also find it at Autozone, O'Reilly and others if I search using the AA10034 number you give. That is apparently not the actual part number, but it comes up. Not a cheap sensor by any means, but you need it obviously...
https://www.autozone.com/collision-b...90-206/717_0_0
Good luck!
Old May 31, 2024 | 9:55 AM
Pierregirard's Avatar
Since you're on a budget and looking at eBay, make sure to buy from a seller with good reviews. Carefully check the part listing to ensure the seller guarantees it will work with your Silverado.
Old May 31, 2024 | 10:00 AM
IZZI613's Avatar
no it dont look like any of them....this is the part that came off the truck.....
Old May 31, 2024 | 10:01 AM
IZZI613's Avatar
thanks...cant believe the prices on these things, let alone trying to find the one thats a match as far as number...there is gotta be a substitute for it
Old May 31, 2024 | 10:50 AM
jfmorris's Avatar
The only thing I can find for a 2008 Silverado that claims to be a front impact sensor is this:
https://www.chevroletpartsdirect.com...UtM2wtdjgtZ2Fz
GM part 85598007
Unfortunatley, they don't have a real picture of it.
This part on Rockauto sure looks a lot like yours, except it has a plastic piece that extends down on the bottom side. You don't show the connector, but if you flip through the photos of the one on Rockauto, is the connector the same as yours?
https://www.rockauto.com/en/moreinfo...pt=1564&jsn=10
Old May 31, 2024 | 10:56 AM
IZZI613's Avatar
yeah thats the GM part number i called the dealer....funny thing is there are so many parts that look like the one on my truck.....remove the sticker and there identical....even the parts guy at the dealer said he dont know if you can mix match....but you know dealers......i know there are replacements for my specific one, but just searching for it...and seen research on mix matching......just a pain for such a small yet important part
Old Jun 4, 2024 | 7:03 PM
ncsouthpaw's Avatar
I had a 2009 Silverado and the service airbag light came on. I was told it was more than likely a bad front impact sensor. I never found a substitute for mine other than going to a junk yard and pulling one off a wrecked truck. The bad part is there is no way of checking one to tell whether it is good or bad. Everyone said you just had to buy one and try it on one side if not put it on the other side. Don’t like spending $100.+ for a guessing game.
Ttrein
Jul 30, 2024 4:39 PM
Spy
Oct 8, 2023 1:46 PM
Landon_92
Oct 25, 2017 4:16 PM
jclaw7877
Sep 13, 2006 10:24 AM
