A/C not working
Old March 19th, 2020, 2:34 PM
garyj044's Avatar
Default A/C not working
I have a 1999 chevy G1500 express conversion van, a/c not working, it will work when i use a jumper wire on the drier clutch cycling switch. tried another switch still did not work. any ideas? thank You
Old March 19th, 2020, 2:41 PM
test fuses/relays
Old March 19th, 2020, 2:49 PM
garyj044's Avatar
are there any other switches other than the clutch switch on the drier that might be bad, and thank you i will check the fuses
and the relay
Old March 20th, 2020, 7:32 AM
Possibly low on freon.
Old March 20th, 2020, 9:10 AM
this!!!
if you are jumping a low pressure switch and it works...maybe you have low system pressure!
woodchipmaker
March 14th, 2015 6:04 PM
birdieb
June 12th, 2014 3:32 PM
max95
June 1st, 2010 9:47 PM
fordchevy
Silverado & Fullsize Pick-ups
May 21st, 2009 8:57 PM
bwty
September 28th, 2008 9:18 AM
Quick Reply: A/C not working
