Driver's side rear door latch upper rod plastic part - what is that called ?
Old November 9th, 2023, 4:10 PM
4mal's Avatar
Default Driver's side rear door latch upper rod plastic part - what is that called ?
I'm speaking of the plastic part that holds the rod in place. Mine is busticated and I have to manually connect it every few drives if I want to open the door...
Thanks!
Old November 9th, 2023, 4:16 PM
https://nemigaparts.com/de/cat_spare...olet/55g-g/16/
Old November 9th, 2023, 4:55 PM
4mal's Avatar
Thanks but my question remains. The drawing appearscomprehensive however it doesn't seem to show the little plastic 'keeper' that holds the rod to the upper latch. Or if it does, it sure isn't ibviois tp me...
Old November 9th, 2023, 7:07 PM
I highly doubt you are going to find that one itty bitty piece for sale anywhere.(except a junkyard). I bet you anything they sell it as an entire latch assembly.
Old November 9th, 2023, 9:17 PM
Triaged's Avatar
One of these work?
https://www.amazon.com/OAUTOO-165pcs-Assortment-Chrysler-Toyota/dp/B0C5VB83XN/ref=mp_s_a_1_4?crid=2SL08U2IN2RJW&keywords=gm+door+linkage+clips&qid=1699585727&sprefix=gm+door+link%2Caps%2C341&sr=8-4 https://www.amazon.com/OAUTOO-165pcs-Assortment-Chrysler-Toyota/dp/B0C5VB83XN/ref=mp_s_a_1_4?crid=2SL08U2IN2RJW&keywords=gm+door+linkage+clips&qid=1699585727&sprefix=gm+door+link%2Caps%2C341&sr=8-4
mountainmanjoe (November 9th, 2023)
Old March 17th, 2024, 11:40 PM
Rgjr702's Avatar
I ended up using a few zip ties when mine broke 2 years ago. Still holding.
Old March 18th, 2024, 7:27 AM
Gumby22's Avatar
Originally Posted by Triaged
This is the right idea - if you don’t want a full assortment, Dorman #75450, 75455 or 703-235 should work.
Mike-g
1988 - 1998 (GMT400)
November 13th, 2022 8:07 AM
phness
Avalanche
11
September 4th, 2022 9:36 PM
alfamia
November 26th, 2021 1:42 PM
Black'95
September 4th, 2015 7:13 AM
smriddler
May 14th, 2015 9:20 AM
Quick Reply: Driver's side rear door latch upper rod plastic part - what is that called ?
