eng-1 fuse keeps blowing
When I turn the key all the way over the eng-1 fuse blows. This has been happening since I hit a pot hole. It may be a shorted wire but this fuse runs to a lot of things. How can I track this down, or does anyone know of a better way to find it? There are no codes showing.
Unhook the things that it supplies, process of elimination. With key on, individually reattach the electrical connections.
Originally Posted by kevinkpk
(Post 362808)
Starter relay?swap with same, from other circuit that's not needed to run
Originally Posted by geo1
(Post 362841)
All the way over,to start"crank"so run is ok?
Alright, so now I noticed that the fuse is blowing as the key is turned on period. It does not have to be turned all the way to the right.
Gotya,so,unplug every fuse and relay, using photo from phone for reassembly,as mentioned above,isolate,then, reinstall till fuse blows
And, what year,etc. is the vehicle,I'll get in the book, otherwise, AutoZone has many electrical diagrams,they and all data are same,the latter is a paid for service,much more info
I've got all o2 sensors, evap purge solenoid, cam shift position sensor, crankshaft position sensor, and mass air flow sensor unplugged and the fuse still blows.
