eng-1 fuse keeps blowing
Old September 15th, 2018, 1:27 PM
rubberpanman's Avatar
Default eng-1 fuse keeps blowing
When I turn the key all the way over the eng-1 fuse blows. This has been happening since I hit a pot hole. It may be a shorted wire but this fuse runs to a lot of things. How can I track this down, or does anyone know of a better way to find it? There are no codes showing.
Old September 15th, 2018, 2:34 PM
kevinkpk's Avatar
Unhook the things that it supplies, process of elimination. With key on, individually reattach the electrical connections.
Old September 16th, 2018, 9:33 AM
It blows when the starter is turned over. After that the starter keeps turning but the engine does not crank.
Old September 16th, 2018, 10:36 AM
geo1's Avatar
Starter relay?swap with same, from other circuit that's not needed to run
Old September 16th, 2018, 12:56 PM
I pulled the starter and fuel pump relay out and as soon as the key is turned all the way over it blows the fuse.
Old September 16th, 2018, 1:09 PM
geo1's Avatar
All the way over,to start"crank"so run is ok?
Old September 16th, 2018, 1:11 PM
Alright, so now I noticed that the fuse is blowing as the key is turned on period. It does not have to be turned all the way to the right.
Old September 16th, 2018, 1:18 PM
geo1's Avatar
Gotya,so,unplug every fuse and relay, using photo from phone for reassembly,as mentioned above,isolate,then, reinstall till fuse blows
Old September 16th, 2018, 1:32 PM
geo1's Avatar
And, what year,etc. is the vehicle,I'll get in the book, otherwise, AutoZone has many electrical diagrams,they and all data are same,the latter is a paid for service,much more info
Old September 16th, 2018, 2:03 PM
I've got all o2 sensors, evap purge solenoid, cam shift position sensor, crankshaft position sensor, and mass air flow sensor unplugged and the fuse still blows.
Quick Reply: eng-1 fuse keeps blowing
