G20 differential removal
Old March 9th, 2019, 11:26 AM
GT1
GT1's Avatar
Default G20 differential removal
On a 1986 short G20 , do I have to remove gas tank to pull the differential out. I have the van up as high as it can go on leaf springs,
above axle line but still have some to go for a straight pull out.
Old March 9th, 2019, 4:06 PM
I don't see why you would need to, but I haven't seen a 30yr old van lately. Can you post a photo?
Old March 9th, 2019, 9:57 PM
jimmydriver's Avatar
No you don't need to drop the tank. You'll need to disconnect the brake lines from the differential, driveshaft, anti lock brake sensors, parking brake cables, and I'd consider new U-bolts and just cut the old ones off.
