Help, break light on after replacing front pads
Hello, I have a 2007 Chevy Express 1500. I replaced the front pads today and now the break light is on. I have done all I know to do which is double check and make sure the emergency brake is off and topped off the fluid in the reservoir. What else could be the culprit? I have heard about a million ideas. What is the most common thing that could go wrong? And FYI. I used a C- clamp on the calipers. I have done this a thousand times and never had an issue.
Thanks for your input in advance.
damaged wheel speed sensors?
You really just need to scan the OBD codes.
Kael (October 11th, 2019)
dab7547
February 15th, 2017 11:16 PM
Mille Racer 69
Silverado & Fullsize Pick-ups
May 19th, 2012 7:27 PM
