Improving mpg on a rebuild
Old March 14th, 2015, 6:42 AM
pengyou1's Avatar
Default Improving mpg on a rebuild
I may be in a position to get a 2003 AWD van for a song...body and interior are in great shape but the mechanical end is very tired. I will (hopefully) run well enough to pass smog when I change the reg, but where I live, I won't have to have anyone stick anything up the tail pipe ever again.
I would like to change it from AWD to 4WD - so that there is a 2WD mode, use a 3.x (1-2) in the rear ends...add tabs to the back of the van, lower it 2 inches, and do a rebuild of the engine and tranny. Any chance I will be able to squeeze 20 or more mpg out of this van? I do a lot of camping on weekends and during my holidays (I am a teacher) but I want to use this as a daily driver as well - I am not in a position to have 2 cars now. The van will have the 2 front driver seats and a bench behind those, then about 500 pounds of stuff for camping.
Any thoughts?
Old March 14th, 2015, 1:44 PM
greenfire's Avatar
I doubt you would do much better than the advertised MPG. If anything you might make it worse doing those modifications.
I would research the current AWD system. You may already be in 2wd until it detects slippage. I am not sure what system these vans have.
I don't understand why you would want to add 4wd and lower the van 2"??? Especially if you are using it for camping. This will effect its payload.. of which isn't much on a 1500.
Old March 14th, 2015, 1:46 PM
dberladyn's Avatar
I agree with the above poster. It's not like the GM engineers intentionally ignore things that improve fuel economy. Maybe in the 1960's, but not now.
Old March 14th, 2015, 3:41 PM
pengyou1's Avatar
Advertised is 17 mpg?
Old March 16th, 2015, 1:18 PM
canucklehead's Avatar
Advertised is based on going downhill with a tailwind.....lol
Expect 13 to 15 average.
highroad
August 9th, 2019 9:27 PM
in2pro
November 5th, 2012 7:11 AM
Everwiser_jr.
September 25th, 2009 4:07 PM
73shark
May 31st, 2007 10:22 PM
Quick Reply: Improving mpg on a rebuild
