p0404 and p0420
Old September 1st, 2013, 7:31 PM
HOMESLICERYRY's Avatar
Default p0404 and p0420
Ok, so my inspection is due, took it to a mechanic and he says I need a new cat, I would like to verify that on my own. I am throwing a p0404 and P0420 code. I replaced the egr valve 2 months ago and immediately afterward i noticed the cars rpms would jump ever so slighly at highway speed, but never did prior. I have my own actron scan tool, but don't fully understand the live data. Are there anyways to tell if my Cat Converter has gone bad? I know the basic symptoms, smell, rattle, cherry red, None if which I have. I was thinking it could be my upstream 02 sensor?
Not to sure though any opinions are appreciated
Old September 1st, 2013, 10:59 PM
Professional Mechanic
MDTAHOE's Avatar
PO 420 is almost always a bad cat. If you want to look for yourself the look at the upstream and downstream O2 sensor data. If the voltages mirror each other then you have a bad cat. Upstream o2 voltage should fluctuate above and below 500mV always, downstream o2 should fluctuate below 500mV when the cat is working.
Old September 2nd, 2013, 10:14 AM
Ok im going to post the live data in a bit! Would a bad cat throw my egr off?
Old September 2nd, 2013, 2:26 PM
Ok So I cleared the codes yesterday, cycled it and the 404 is no longer there. p0420 has come back after 40-50 miles.
Heres a few posts of the live data
Attached Thumbnails p0404 and p0420-img_0377%5B1%5D.jpg   p0404 and p0420-img_0383%5B1%5D.jpg   p0404 and p0420-img_0384%5B1%5D.jpg
shayandude
February 28th, 2015 3:27 PM
98coppermetallic
Silverado & Fullsize Pick-ups
October 14th, 2010 7:20 PM
headache2000
Astro
May 25th, 2010 10:40 PM
j0nblazeish
Uplander
September 25th, 2009 6:42 PM
ddesens
August 27th, 2006 1:38 PM
Quick Reply: p0404 and p0420
