PCV valve location
#11
Hmm. My gasket was new...
I remember that I put the gasket on the heads and not on the manifold before I put all together. That could be an issue?!
Steam leak test did not show any leaks.
Anyway, I have toi check this.
What I am curious about...
On every picture the left valve cover looks like the one with the pcv valve on top of the cover.
But mine looks different and I don't have a pcv... The picture was taken before I took all apart
#12
When you service head gaskets, you're supposed to change everything while you're in there. Just buy a kit .... valve seals, intake gasket, fuel o-rings, ... everything. When you take something apart, don't reuse seals , or else you'll be back in there again soon.
Mist some starting fluid, or propane, or even water around the bank 1 manifold and see if the idle changes. Or smoke it out.
#13
#14
Also a steam leak test doesn't show any results. Yesterday I took out the manifold. Just waiting on some new parts.
Heads a reworked last year. Valves, valve seats etc are all new.
I hope that the problem was the gasket.
I also hat some P0332 codes from time to time. Checked the sensors. Both are ok and show up the correct reading
#15
#16
I will hope that the new sealing will solve that problem.
#17
Just to follow up on that issue...
MAF is off, after changing the intake gasket. For most of the time.
But: I have still a P0101 in my storage. And you can feel that there is something "wrong". I have a lack of power, when there is a steep uphill or when I have to accellerate.
If I clear the code, the engine runs good. But the code pops of very shortly. Without MIL...
2 days ago the MIL was on again.
With this reading. Is there any sign that there still is a leak? I can't read the trim data...
Thanks for helping me out!
