Problem: Stuck in gear, cannot park
Old April 22nd, 2013, 6:13 PM
mak1na's Avatar
Exclamation Problem: Stuck in gear, cannot park
Hi guys, I'm a new member to the Chevy community and posting on behalf of my father.
I did a search prior to this thread but I saw nothing useful or similar.
I have a 2004 Chevy Express 2500 and as of recent, I have not been able to put the car into park. It turns on and shuts off fine, and can move from any gear from R,N,D,3,2,1, etc.. Park does not seem to work, the shifter locks up at the gear before park.
Maybe its the wiring?
Anyone have a clue? That would be greatly appreciated!
Old April 23rd, 2013, 12:17 AM
canucklehead's Avatar
Check the linkage cable. If its not adjusted properly it will not go into park. I had mine break, and I had to open up the steering column and pull back part of the ignition key mechanism with a screwdriver to get it to go into park. However, once I replaced the cable, it worked fine again.....I was worried that it was a separate issue, but the new cable fixed all.
Old April 23rd, 2013, 11:32 AM
mak1na's Avatar
Thank you for the swift reply. I will be trying to fix this today!
BigblackHo3
April 5th, 2013 8:54 AM
sathishraju
Cruze
November 2nd, 2012 9:55 AM
romanlu
July 8th, 2009 7:55 PM
bdm408
Silverado & Fullsize Pick-ups
September 11th, 2008 8:55 PM
bdm408
September 7th, 2008 6:24 PM
Quick Reply: Problem: Stuck in gear, cannot park
