stranded. van wont start
Old July 26th, 2020, 11:10 AM
P0well's Avatar
Default stranded. van wont start p0496
Check engine light came on this morning, went to auto store to see what the code was for and got a p0496 evap emissions high purge flow... i bought a new solenoid and the van died on the travel back. I put the evap solenoid in while stranded but van still wont start. It did a wierd thing while it was driving after a semi hard brake, it kept beeping fir a good 10 beeps. Like the alarm that sounds when you leave the keys in. So now the starter just keeps going and van doesnt start. Hoping its not actually the fuel pump
Would a bad canister vent valve cause this?
Old July 26th, 2020, 12:11 PM
no idea what year or engine you have so hard to state specifics.
remove the gas cap and try starting it.
although i have never seen it, in theory, if the vent line is plugged completely it could cause a high ftp sensor reading ie high purge. if air can't get in to the tank when fuel is pumping out it can collapse the tank and stress the fuel pump.
if you think you have a fuel pressure issue...remove the air snorkel at the throttle body and spray a 3 second shot of brake cleaner into the intake manifold. if it runs briefly...you have a fueling problem.
Old July 26th, 2020, 12:13 PM
P0well's Avatar
Its an 08 4.8. Ill try the gas cap thing. I dont have much to work with since im stil waiting for my ride
Still didnt start with gas cap undone.... confused why it came up with an evap code if it was fuel delivery issue
Ill make a note that i did use a bottle of fuel additive to clean the grime n such just yesterday with 3/4 of a tank and suspect that lead to this
sounds like my fuel pump might be fried, ill try the brake cleaner when my ride gets here
Old July 30th, 2020, 8:37 PM
P0well's Avatar
Just wanted to follow up. So it ended up being the fuel pump. Kinda weird that it gave evap codes.
Johnny Mayday
October 18th, 2018 8:53 PM
David Tyo
September 12th, 2017 5:46 PM
gamingglory
July 29th, 2017 4:10 PM
KimberlyHaltom
January 2nd, 2013 8:54 PM
quinn
October 19th, 2010 9:11 AM
Quick Reply: stranded. van wont start
