What amp alternator comes stock on my van (06 2500 express, passenger)
#14
I have been on a $10/mo Compnine's plan for over 2 years now. Yes they don't have some of the newer vehicles, but prior to 2015 they have everything and the data is 100% accurate. Never let me down.
The VIN decoder here on this site just gives you basic info applicable to the whole model line-up. It determines the type of vehicle, engine, transmission, GVWR, wheelbase correctly. But not the small build options.
#15
1GAGG25V861227006
Vehicle: VAN 3/4 TON PASSENGER EXPRESS
Year: 2006
Build Date: 2006-03-16
Found 1,383 vehicles matching that year and model in our database.
RPO Description Matches
U1C RADIO,AM/FM STEREO,CD PLAYER,ETR, CLOCK STEREO W/CD PLAYER(U1C) 939
U73 ANTENNA,FIXED FIXED ANT(U73) 1,383
VG8 LABEL,NOTICE TO BUYER NOTICE TO BUYER LABEL(VG8) 177
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 1,379
VP6 NOISE LEVEL CONTROL NOISE LVL CONT(VP6) 243
VXS VEHICLE - COMPLETE 1,383
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 1,294
V95 TIRE WEIGHT TAX - NON-TAXABLE 719
WEN PLANT CODE - WENTZVILLE, MO, BOC WENTZVILLE,MO ASSEMBLY PLANT(WEN) 1,383
XHF TIRE FRONT LT225/75R16/E BL R/PE ST ALS(9591204) TIRE(XHF) 1,319
X88 CONVERSION CHEVROLET CHEVROLET(X88) 1,383
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3) 1,383
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5) 1,383
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6) 1,383
YF5 CALIFORNIA EMISSION CERTIFICATION CALIFORNIA EMIS CERTIFICATION(YF5) 177
YHF TIRE REAR LT225/75R16/E BL R/PE ST ALS(9591204) TIRE(YHF) 1,319
YK6 IDENTIFICATION - (SEO) 797
ZHF TIRE SPARE LT225/75R16/E BL R/PE ST ALS(9591204) SPARE TIRE(ZHF) 1,319
ZQ2 DRIVER CONVENIENCE PACKAGE DRVR CONVENIENCE PKG(ZQ2) 1,173
ZW9 BASE BODY OR CHASSIS BASE BODY/CHAS(ZW9) 1,383
ZX5 SEATING ARRANGEMENT,TWELVE PASSENGER TWELVE PASS SEATING(ZX5) 1,296
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1) 1,365
1LS PACKAGE LS OPTION 1 "LS" PKG 1(1LS) 1,170
1SZ PACKAGE OPTION- (1SZ) 1,191
50U PRIMARY COLOR EXTERIOR, OLYMPIC WHITE (93) (50U) 440
6ZC COMPONENT FRT LH - COMPUTER SEL SUSP (6ZC) SUSP(6ZC) 423
7ZC COMPONENT FRT RH - COMPUTER SEL SUSP (7ZC) SUSP(7ZC) 423
93I INTERIOR TRIM VERY DK GRAY (I) (93I) 1,077
93W TRIM COMBINATION VINYL, MED DK PEWTER II (W) (03) (GMT610 - "G" VAN) (93W) 519
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5) 1,383
AR7 SEAT,FRONT BUCKET FRT BKT ST(AR7) 563
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 1,187
AXQ VIN IDENT POSITION, BUS BUS VIN IDENTIFICATION POSITION(AXQ) 1,296
A17 WINDOW,SWING OUT GLASS,LH SWING OUT GLS(A17) 1,314
A18 WINDOW,SWING OUT GLASS,REAR DOOR SWING OUT GLS(A18) 1,312
A31 WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31) 1,173
B38 COVERING FLOOR VINYL, FRONT AND REAR, FULL WIDTH FLR CVR,FRT RR VINYL(B38) 657
C36 HEATER,AUXILIARY AUX HTR,RR(C36) 1,301
C6P GVW RATING 8, 600 LBS/3, 900 KG 8600 LB/3900 KG GVWR(C6P) 1,383
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 1,383
C69 AIR CONDITIONER,RR AUX RR AUX A/C(C69) 1,288
C99 SWITCH INFL RST I/P MDL MAN SUPPRESSION MAN SUPPRESS INFL RST I/P MDL SWITCH(C99) 1,383
DE5 MIRROR,OUTSIDE,LH & RH,REMOTE CONTROL,ELECTRIC,DEFOG,FOLDING,PAINTED O/S MIR(DE5) 990
DH6 MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM) ILLUM S/S MIR(DH6) 1,050
D31 MIRROR,INSIDE,REARVIEW,TILT RR VIEW TILT MIR(D31) 1,284
E2C ORDER TO DELIVERY - EXPEDITE TO CUSTOMER 1,352
E24 DOOR,HINGED SIDE REAR CARGO/SEAT ACCESS HGE CARGO/SEAT ACCESS DOOR(E24) 1,122
GAM VEHICLE - GOVERNMENT (G.S.A. SALES) 719
GT4 AXLE,REAR,3.73 RATIO 3.73R(GT4) 1,240
JH6 BRAKE HYD POWER, 4 WHL DISC, 9,900 LBS BRK HYD PWR DISC(JH6) 1,383
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4) 1,383
KD1 COOLING SYSTEM,TRANSMISSION OIL TRANS OIL CLG(KD1) 1,383
KG3 GENERATOR 145 AMP 145 AMP(KG3) 1,294
LR4 ENGINE GAS, 8 CYL, 4.8L, MFI 4.8V(LR4) 1,021
MT1 TRANSMISSION,AUTO,4-SPD,THM-R2(4L80-E) 4-SPD A/TRANS(MT1) 1,315
NA4 EMISSION SYSTEM,ABOVE 8500 LB GVW EMIS SYS(ABOVE 8500 LB GVW)(NA4) 1,374
NU1 EMISSION SYSTEM CALIFORNIA, LEV2 CALIFORNIA LEV2 EMIS(NU1) 270
PDN CONTROL - SALES ITEM NO. 131 852
R6P CONTROL - SALES ITEM NO. 15 1,173
R8K CONTROL - SALES ITEM NO. 61 1,074
R9R CONTROL - SALES ITEM NO. 92 719
R9Z CONTROL - SALES ITEM NO.100 901
TFD SALES INCENTIVE - RETAIL AMENITIES - DELETE 1,184
TR9 LAMP GROUP,COURTESY LP GRP(TR9) 1,050
Year: 2006
#17
Hey StanVan, (or anybody else) I just called one of my local Chevrolet dealers, and asked if they could/would decipher my VIN Number with a printout, including RPO's, they said sure. I asked how much($), she said no charge, you might try that sometime.
#18
I'm good. I have a pic of my RPO sticker, and found a listing of RPOs. It did take me a while to track it down, and truthfully I don't remember where it was. But I downloaded it It strikes me as odd that some lists are incomplete, or that some codes are reused.
#19
I suggest you call your closest Chevy dealer, and ask if you can come down righ now, and get a complete VIN, and RPO printout. 🙂
#20
What I downloaded was a complete list of 2017 RPO codes. I couldn't find one for 2016. I've looked in to a couple of them, like the alternator thing, just because of recent threads and comments. But I haven't looked them all up yet.
My reference to "reusing" RPO codes was related to one link I found. In my Googling, in a link in to a Chevy truck forum, a guy was mentioning that over the years, Chevy reuses the codes, so like 10 years ago, a code meant something different than it might now. Not always, but it can happen. That seems confusing, but if you think about it, when you're using only 3 digits, numbers and letters, there are only so many combos. In dealing with alternators, for example, how many different ones has GM used in the last 50 years? That actually might touch on when they used generators.
