03 express steering column cover
Old Jan 27, 2017 | 4:47 PM
steve/cindi's Avatar
Default 03 express steering column cover
Hello, I am new here.
how do you remove steering column cover? I don't see any screws in the bottom holes. I have to replace turn signal switch. thanks for any information, Steve
Old Jan 30, 2017 | 12:16 AM
Artie1's Avatar
Just separate them apart with your hands. It's held together with plastic latches.
Old Feb 5, 2017 | 1:20 PM
thank you, I got it apart and switched turn signal switch. still no low beam headlight, where else can I look for culprit
Old Feb 5, 2017 | 2:04 PM
cleaned the fuses and relay. even swapped relays still no low beams. yes bulbs are new
