05 Express upgrade Interior dome light to add map light, is it possible ?
Hi Everyone,
This is my first post, I checked the posting to see if I could find a solution for this upgrade, but I couldn't find one. Is it possible to replace the front/driver interior dome light on a 2005 Express 1500 so that there is separate map light. I don't like to turn on all 3 dome lights in the van just to read a map.
Thank You
Paul
Thank You
Paul
Sure. Go to an auto wrecker and pick up the factory one. Or get an aftermarket one.
If you have to run a separate power wire for the map lights then just go off the fuse panel. However there may be the wire there already.
rganner
December 19th, 2013 1:07 PM
