120v Inverter location
Old Oct 9, 2023 | 8:43 AM
2018E2500's Avatar
Default 120v Inverter location
Does anyone know the location of the 120v inverter module in a 2018 Express 2500? I have looked under the dash, under the seats , and under the hood...... I am replacing because it blows the inverter fuse every time something is plugged in, no matter what.
Thanks!
Old Oct 9, 2023 | 1:32 PM
inverter location
Old Oct 9, 2023 | 2:04 PM
2018E2500's Avatar
MMJ, Would you say that is the top of the dash assembly, under the dash pad? Or is that a view from the bottom?
Thanks!
Old Oct 9, 2023 | 3:00 PM
you have to remove the dash top
Old Oct 13, 2023 | 9:29 AM
2018E2500's Avatar
BIG Thanks to MMJ for the information. Finally got around to changing the module this morning. The job was relatively easy, I popped the front bezel loose from the dash without removing it, allowing access to 4 screws that hold the dash pad in position, Remove the screws and pull the dash pad to the rear to unlock it. Now you can lift it up and access the module.
Lift up the dash cover.
Remove the 4 bolts that hold the module.
Old Mar 30, 2025 | 1:19 AM
Samguy2000's Avatar
Do you have any more pictures of when you did this project, and the part number? I gotta tackle this project soon.
Old Mar 30, 2025 | 1:21 AM
Samguy2000's Avatar
inverter location
Do you have any better diagrams than that? Gotta tackle this project soon. Don't even know the part number or where to begin unscrewing.
danger
Trax
Jul 29, 2023 1:15 PM
Courtland1949
2014 - 2018 (GMT-K2)
Jul 28, 2023 3:18 PM
motox299
Dec 31, 2015 11:39 AM
lennyAIM
Uplander
Feb 1, 2008 7:44 AM
gary1046
Cobalt
May 21, 2007 11:50 PM
