1995 Chevy G20 Gladiator - fuel system problem
Old Jan 24, 2018 | 7:39 PM
2jdcrosby's Avatar
Newly Registered
Default 1995 Chevy G20 Gladiator - fuel system problem
1995 chevy g20 gladiator - van will start with starter fluid for a few seconds - have a new filter to install - fuel pump relay switch to install - Question?
where is the relay switch located ?
need some step by step instructions on dropping fuel tank ( disconnecting fuel lines etc. ? and replacing fuel pump.
Thanks
Old Jan 25, 2018 | 6:03 AM
Check out YouTube. They have videos for everything. The relay should be in the under hood fuse box.
Old Feb 1, 2018 | 2:56 PM
Hanes manual
Old Feb 3, 2018 | 6:57 PM
ThroatwarblerMangrove's Avatar
Which engine do you have? I'm assuming it's a gas engine.
Fuel pump relay is located on cowl next to windshield washer tank.
