1996 express 1500 trans issues
Old Nov 16, 2014 | 9:11 AM
Commish56's Avatar
Default 1996 express 1500 trans issues
96 with 4.3 10
Transmission(4l60e m30, no removable plate at bellhousing)
started to act up 2 weeks ago. Had to go high rpm for reverse to work. But once it caught was no problem. Also felt like it stayed in 1st gear. Yet again had to go to high rpm and let off gas to up shift. Replaced with a 4l60e m30 no removable plate from a 98 Sonoma. Tried old torque converter and one that came with 98 sonoma trans. Same problem in both instances as original trans. What can be issue?
Old Nov 16, 2014 | 9:13 AM
Commish56's Avatar
Default added info
Replaced ecu last year do to corrosion and starring issues. Brand new and programmed. Also shows no cel and only stored codes were a knock sensor and one for a exhaust leak.
Old Nov 16, 2014 | 11:01 AM
canucklehead's Avatar
What are you using for a code reader? Maybe you need a big shop one to find out the issue. A bad crank pos sensor or cam pos sensor can cause shift issues.
Old Nov 16, 2014 | 6:44 PM
Commish56's Avatar
Used a handheld of a friends and at autozone.
Old Nov 16, 2014 | 11:22 PM
Not sure then. I'm lucky to have a local tranny shop that ran my code for free to find out my issue being a bad camshaft position sensor. It was causing my lockup on the TCC to click on and off.....
Chevrolet Forum News
Jul 15, 2014 4:48 PM
bobbygrady
Aug 8, 2013 11:49 AM
tmw1040
Aug 8, 2012 7:37 PM
monteman85
Feb 17, 2009 5:05 PM
350 Chevy
Jul 7, 2007 4:17 PM
