Old Feb 12, 2012 | 12:51 AM
bakkenman's Avatar
Default 1997 5.7
Is it normal for the upper intake (plastic) to swell when I rev engine to approx. 3000 rpms.
Old Feb 18, 2012 | 3:45 AM
Northstar's Avatar
no it's not supposed to "swell". I don't even know how it could swell.
Please explain what it is doing in more detail and I'll try to help you more.
Old Feb 19, 2012 | 10:52 PM
bakkenman's Avatar
I replaced the lower intake manifold do to some sludge on my radiator cap. I found a leak in front where the silicone seal's between the manifold and top of block. I installed a new upper manifold as well (plastic), replaced the spider injectors and pump, she has never run this good in a long while. I can now run 87 octane fuel and have no pinging. It has 220k on it. Last time I could run that fuel is when it had 90k on it. Thats when i had my 100k tune up done alittle earlier by dealer, ever since then I always had to run 91 octane in it to prevent pinging. After my repairs i did my testing, service engine light went out, no leaks, when i was reving engine to approx. 3000 rpms i would watch where the injector connection is and it swell in size, rise up approx. 1/8''. Still running strong. Just concerned, you think it would contrac and not expand?
Old Feb 23, 2012 | 12:30 AM
Northstar's Avatar
I would think there would be a vacuum in the manifold. Are you sure it's not the whole engine moving on the motor mounts? Still not sure how the intake would "swell".
Big boy toys
Jan 16, 2008 11:03 PM
Big boy toys
May 1, 2007 10:33 PM
Big_SPike_91
Jul 5, 2006 11:36 PM
BigD6765
Jan 13, 2006 4:19 PM
craver5
Dec 7, 2005 12:04 PM
