1997 GMC SAVANNA 2500 TRANSMISSION
Old Apr 22, 2006 | 8:26 PM
BILLSONG's Avatar
Default 1997 GMC SAVANNA 2500 TRANSMISSION
I have a 1997 GMC Savanna 2500 5.7L.
My Transmission doesnt shift from first gear. Top speed is 15MPH.
It goes up to 15MPH while I'm driving around the block after car doesnt move forward anymore. After about 5-7 minutes after shutting down the car it would move for a while then the same thing happen.
Also I dont know if this help but if I start it up and let it warm up it would move only out of my driveway.
Old Apr 22, 2006 | 9:09 PM
Nomad76lj's Avatar
Default RE: 1997 GMC SAVANNA 2500 TRANSMISSION
the first thing i would try would be a tranny flush with a new filter and see what that does for u.
Old Apr 22, 2006 | 11:05 PM
BILLSONG's Avatar
That whats I'm thinking. But would an ATF fluid really solve this big issue.
Old Apr 22, 2006 | 11:11 PM
Nomad76lj's Avatar
it might its the cheapest thing to try first. pull the dip stick and smell it you should be able to see if the fluid is bright pink or black and burned smelling. then go from there. my buddys car wouldent even drive over a speed bump untill we changed the fluid.
Old Apr 23, 2006 | 12:05 AM
BILLSONG's Avatar
OK thank for the thought.
Old Apr 23, 2006 | 1:39 AM
Nomad76lj's Avatar
no problem. post again and let me know what u find out.
Old Apr 26, 2006 | 5:38 PM
BILLSONG's Avatar
Well your right, I change the fluid and filter and it ran fine. No hard shifting. Thank for the help and saving my time.
Old Apr 26, 2006 | 11:02 PM
Nomad76lj's Avatar
no prob. glad i could help.
Old May 22, 2006 | 5:47 PM
BILLSONG's Avatar
Well now the trans fluid is brown. I think I need to chain the fluid in the torque converter. How do I do It
Old May 22, 2006 | 6:16 PM
Nomad76lj's Avatar
i think by changing the fluid a few time with cheap fluid then puting the good stuff in should do it. to change the fluid in the converter would require taking out the tranny. once your done it should be brite red and stay that color. and i forgot drive it a bit between each change to run the fluid though it good.
