1999 Express Speedometer Sticking
Old Feb 20, 2023 | 9:47 PM
Skyhawk1961's Avatar
Default 1999 Express Speedometer Sticking
My recently acquired conversion van with 38,000 miles has a sticky speedometer. Sometimes high, sometimes low and sticks momentarily on the way up and down. Is it a bad gauge or is there a sending unit on the transmission that controls this?
Old Feb 21, 2023 | 12:13 AM
Plug in a diagnostic scanner and go for a drive.
If the speed on the tool is normal, then the problem is your cluster. If it's not then it's the sensor.
Old Feb 21, 2023 | 7:44 AM
Probably the stepper motor in the speedometer. They can be replaced instead of replacing the cluster and they are not very expensive..
Old Feb 21, 2023 | 6:03 PM
Thank you. Any idea as to source of supply and can it be a do it yourself job?
Old Feb 22, 2023 | 6:43 AM
I did a 2003 Trailblazer and it was easy if you can solder. I replaced all 6 while I was in there. The 1999 is a different stepper motor and I am not sure how easy it is. They are available on Ebay and you can look to see if Youtube has
a video on how to do it.
FireEMT978
Apr 10, 2022 1:56 PM
Terry Apple
Jun 19, 2016 6:19 PM
qureshza
Dec 23, 2012 11:03 PM
4greens
Apr 18, 2010 5:00 PM
04chev
Aug 31, 2007 12:42 PM
