2001 chevy express 3500 no start no link to odb2
Old Jun 5, 2019 | 6:57 PM
Tenleyo's Avatar
Default 2001 chevy express 3500 no start no link to odb2
One morning, van just cranked, i heard no power to fuel pump so i replced it, no change. Cant link with odb2 scan, no power to fuel pump, the pump will 'thud' every so often when key is turned,, getting power to odb port. ,ground on pins 4 and 5, only. .1 volts on pin 2, any ideas?? Thank you
Old Jun 5, 2019 | 9:36 PM
Check the easy stuff ... fuses.
Old Jun 5, 2019 | 10:04 PM
Tenleyo's Avatar
I checked them
Old Jun 5, 2019 | 10:25 PM
Next I would use a multimeter or test light, and see where along the fuel pump circuit the voltage stops. You can find diagrams here:
BBB Industries- Premium Alternators, Starters, Power Steering Products and Turbochargers | TSB and Wiring Diagrams Database
Old Jun 6, 2019 | 7:04 PM
Irish_alley's Avatar
I'm here for the party
Originally Posted by Tenleyo
I checked them
how did you "check them"? best bet is to use a tester of some sort and not visual
Old Jun 8, 2019 | 4:44 PM
Tenleyo's Avatar
I did find a blown fuse, dome light but it made no change, i found that if igo back and forth with the key i eventually get the hum from the fuel pump and the fuel gage activates, when i get that iturn the key to start and it starts right up and runs fine. Whats going on here?, ignition switch?
Old Jun 8, 2019 | 5:30 PM
Who knows. More troubleshooting required.
At least hook up a light to the pump and see if it comes on every time.
Old Jun 8, 2019 | 5:51 PM
Tenleyo's Avatar
It doesnt come on, until i goback and forth with the key a few times
Old Jun 8, 2019 | 6:13 PM
You already said the pump isn't coming on. I'm suggesting putting a light there. If the light comes on and the pump does not, then you've isolated the problem. It's called troubleshooting.
Old Jun 8, 2019 | 6:46 PM
Tenleyo's Avatar
No power to pump until a few turns off and on
