2001 Chevy express not starting
Its cranking but not starting, when i turn the key it sounds like it wants to start. I get a few puffs of exhaust slowly. but wont crank. Battery is good, i can hear fuel pump, ran fine yesterday. Where could i start checking?
It was cranking but it wouldn't run. I tried it again when I got home from work and it started and ran later in the day. I had the hold the key forward for a while and let it turn over for a min or so. I'm assuming the engine was flooded or not getting gas. Occasionally when I drive it up a hill in the past I get misfiring. Could that be a bad injector?
I had a 2001 that did the same thing,on top of the engine on the drivers side (towards the back side)injection tube is a schrader valve,I took the cap off & pushed on the valve stem in it which must of released pressure in the system & it started & has been running ok since.
