2003 Chevy Express 6.0 Head Removal
Old Aug 20, 2010 | 4:01 AM
BobbyBrown1972's Avatar
Default 2003 Chevy Express 6.0 Head Removal
Can someone let me know if I can remove the heads on my van without pulling the motor out just need to know how big of a project I have.
Old Aug 20, 2010 | 3:39 PM
suzuki-guy's Avatar
YOu should not have to pull the motor out but it is still a pretty big job! Are you mechanically inclined?
Old Aug 22, 2010 | 12:36 AM
I think a little just changed a head gasket on a 1996 Ford Contour 2.0 with success. I don't want to give a garage $2,000 for my repair if I can try myself on my own time. The problem I have is a dead cylinder drivers side farthest one back so I think what happened is either a intake valve missing a section or broken off because with the valve cover off the rocker arms are moving like they should.
Old Oct 4, 2010 | 7:55 AM
hfl67's Avatar
Did you get it done? I have to do the same on my 2000, looking for advise/encouragement?
Old Oct 19, 2010 | 8:38 AM
hfl67's Avatar
I just completed the head removal/replacement on my 2000. I'm pretty mechanically inclined, but really all it took was time. I asked the same question on an earlier post. Something like 14 hours to pull and 15 hours to put back in.
I got the Haynes and made 15 strips of paper with numbers on the top and went through it like a choose your own adventure book. It was earlier than yours (2000), but I think yours would actually be easier due to coil packs, better fuel injection and one piece intake (?). Buy the book and a torque wrench and pay attention and you'll do fine.
Old Apr 22, 2017 | 1:59 PM
Lbeelman's Avatar
so what was the outcome and cause for your dead cylinder repair? was it part of intake valve missing?
Old Apr 24, 2017 | 12:27 AM
Artie1's Avatar
If you have a car lift - It only takes 1 hour to pull the body off the frame... will make working on the engine much easier, and you could refresh a lot of other things while you're at it!
Old Apr 24, 2017 | 3:51 PM
solwav's Avatar
Do not know the answer but just food for though, you likely will have to remove the intake and heads to pull the motor out the front anyways I have replaced 11 van motors Dodge,Ford and Chevy motors the Chevy motors have the least clearance in the engine bay. If my memory serves me right the heads do come off with the motor installed.
To remove your motor would require removing the grill, headlight assemblies header panel radiator A/C condenser bla bla bla a lot of work
and we used a Bobcat with forks and a few links of chain to back the motor out of the engine bay. The most difficult when compared to Ford and Dodge but it is what it is. You seem hesitant I will say if you need to replace the heads or gaskets just do it.
Replace the heads with the engine installed assume a entire day maybe two (a weekend) so you don't rush and break something or hurt yourself. I would expect to break something or encounter one bolt that will take 3 hours to remove. as hfl67 said it will take time and you may need a break to keep your sanity so give yourself enough.
After you have completed the job you will question why you were so concerned.
Best of luck.
Chevrolet Forum News
Dec 28, 2014 6:18 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
NovaProject
Nov 6, 2010 12:35 PM
xzspk5
Jul 4, 2009 6:59 AM
